Structural Design
Structural Catalogue
Sample Joints
: Joint Type Codes
Joint Type Codes
The table summarises the joint type codes that are available in the catalogue.
Joint Group
Joint Group Description
Sub-type Code
Sub-Type
Joint Type Code
Joint Type
J1
Beam to Beam Joints
S1
Equal Size Beams
WEL
Welded
BWC
Bolted Web Cleats
BEP
Bolted End Plate
BFP
Bolted Fin Plate
S2
Small to Large Beams
WEL
Welded
BWC
Bolted Web Cleats
BEP
Bolted End Plates
BFP
Bolted Fin Plate
PLH
Plated Haunch
SNS
Snipe and Stiffeners
SNG
Snipe and Gusset
S3
Large to Small Beam
WEL
Welded
BWC
Bolted Web Cleats
BEC
Bolted End Plates
BFP
Bolted Fin Plate
PLH
Plated Haunch
J2
Beam to Column Joints
S4
Column Flange
FPL
Fin Plate
FEP
Flexible End Plate
FDE
Full Depth End Plate
BWC
Bolted Web Cleat
S5
Column Web
FPL
Fin Plate
FEP
Flexible End Plate
FDE
BWC
Bolted Web Cleat
TOE
Toe Plate and Stiffener
S6
Tubular Column
WEL
Welded
DOP
Doubler Plate
FPL
Fin Plate
SEP
Stub Brkt End Plate
J3
Splice Joints
S7
Equal Sections
APE
Apex Haunch (Moment)
BSP
Bolted Splice Plates
DPL
Division Plate
EPL
End Plates
S8
Unequal Sections
BSP
DPL
Division Plate
EPL
End Plates
J4
Bracing Joints
S9
Bolted Connection
BOL
Bolted Connection x 2 Holes
BOL
Bolted Connection x 4 Holes
S10
Welded Connection
WN1
Wing Plate - 1 x Stiff
WN3
Wing Plate - 3 x Stiff
J5
Baseplate Joints
S11
Baseplate
SQR_4H
Sqr./Rect.4 x Holes
Sqr./Rect.4 x Holes - Stiffs.
SQR_6H
Sqr./Rect.6 x Holes
Sqr./Rect.6 x Holes - Stiffs.
CIR_4H
Circular 4 x Holes
Circular 4 x Holes - Stiffs.
CIR_6H
Circular 6 x Holes
Circular 6 x Holes -Stiffs.
