Structural Design
Structural Catalogue
: Sample Joints
Sample Joints
Hierarchy
The catalogue contains a separate CATA element for joints.
The hierarchy for joints is divided into joint groups, for example, similar joint types are grouped together in an STSE element.
Each STSE element owns one or more STCA element, one for each joint type.
Each STCA element owns all the elements that define the joint, for example, JOIN, GMSE, NGMS, PTSS, PTSE and DTSE.
The joint groups and sub-types are:
Beam to Beam Joints
Equal size beams
Small beams to large beams
Large beams to small beams
Beam to Column Joints
Beam to column web
Beam to column flange
Splice Joints
Equal sections
Unequal sections
Bracing Joints
Bolted connections
Welded connections
Baseplates
Rectangular
Circular
