Press the down arrow key and select Flat to create a flat section plane. Refer to Create 3D Flat Section Plane for further information.
Press the down arrow key and select Perpendicular to create a perpendicular section plane. Refer to Create 3D Perpendicular Section Plane for further information.
Press the down arrow key and select Previous to undo the last action.
Press the down arrow key and select Side to define which side of the section plane displays in the view. A hatched area indicates the side of the section plane that an area of the view is removed from.
Press the down arrow key and select Close to create a closed section plane.
Press the down arrow key and select Open to create an open ended section plane by moving the cursor across the view.
Press the down arrow key and select Stepped to create a stepped section plane. Refer to Create 3D Stepped Section Plane for further information.
Press the down arrow key and select Perpendicular to create a perpendicular section plane. Refer to Create 3D Perpendicular Section Plane view for further information.
