DRAW
Create and Modify Views
The 3D View
: Define Limits
Define Limits
Defines the limits of a 3D view.
The view limits are derived from the elements in the drawlist and display in the view. For example:
The limits display in the fields in the
Define Limits
group. For example:
Move Limits Box
Moves the limits box to a specified position.
Double click the limits box to display editor grips and select the cube grip.
You are prompted to
Specify move point
Input values in the dimension fields and press
Enter
or click to identify the limits box position.
The limits box is moved and the command ends automatically. By default, the limits fields are updated accordingly.
Modify Limits Box
Sets the size of the limits box along a single axis.
Double click the limits box to display editor grips and select a cone grip.
You are prompted to
Specify absolute value or
Input a dimensional value in the field and press
Enter
The limits box is modified and the command ends automatically. By default, the limits fields are updated accordingly.
Throughout the limits box modification process you can press
ESC
to cancel the command. Additional functionality is also available.
Expand
Press the down arrow key and select
Expand
to scale the limits box.
You are prompted to
Specify expansion or
Enter
The limits box is scaled and the command ends automatically. By default, the limits fields are updated accordingly.
