DRAW User Guide
Create and Modify Views : The 3D View : Format 3D Tab
3D views are formatted using the Format 3D tab. The tab displays when a 3D view is open.
The direction can be defined in East, West, North, South, Up and Down directions using the drop-down lists.
Refer to Define Limits for further information.
The direction can be defined in East, West, North, South, Up and Down directions using the drop-down list.
Select Open to define a section plane as an open ended shape. For example, an L shape consisting of two planes.
Select Closed to define a section plane as a closed shape. For example, a rectangle.
For an existing view, the functionality is equivalent to clicking Restore and then clicking Apply. The current scale and view direction are not saved. Modifications to the view content and section planes are saved. The view is resized to the limits.
