DRAW
Create and Modify Views
The 3D View
: Add and Remove Model Items to/from the 3D View
Adds an item to the 3D view or removes an item from the 3D view.
To add an item to a 3D view, select the item in the Model Explorer and drag it into the 3D view.
Alternatively, select the item in the Model Explorer, right-click and select
3D View
, select
Add
Add Connected
or
Add Within Volume
from the drop-down menu.
Alternatively, an item can be added to the 3D view using the
Format 3D
tab. Refer to
Format 3D Tab
for further information.
To delete an item from a 3D view, select the item in 3D view, right-click and select
Remove from 3D View
3D View
, select
Remove
Alternatively, an item can be removed from the 3D view using the
Format 3D
tab. Refer to
Format 3D Tab
Tab for further information.
Alternatively, an item can be removed form the 3D view using the
View Contents
window. Refer to
View Contents
