Press the down arrow key and select Share Drawlist to reference the drawlist from the source view drawlist.
Press the down arrow key and select New Drawlist to create a new drawlist as a copy of the source view drawlist.
Press the down arrow key and select Stepped to create a stepped section view. Refer to Create Stepped Section View for further information.
Press the down arrow key and select Side to define which side of the cutting plane displays in the section view. A hatched area indicates the side of the cutting plane that an area of the view is removed from.
Press the down arrow key and select Flat to create a flat section view. Refer to Create Flat Section View for further information.
Press the down arrow key and select Close to create a closed cutting plane.
Press the down arrow key and select Open to create an open ended cutting plane by moving the cursor across the view.
Press the down arrow key and select Create Second to create a second cutting plane.
