DRAW
Create and Modify Views
: Create Views
Create Views
If a Sheet has been created from a template, the Sheet normally contains at least one View, depending on how the template has been set up by the administrator. An existing View can be modified using the Format 2D tab (refer to
Format 2D View
for further information), Further Views can be created on a Sheet using the options on that tab, or on the
Home
tab in the
View
group. You must be at Sheet level or below before a View can be created.
Attributes set at Sheet level are inherited as the default attributes of Views within the Sheet.
There are several methods of defining a View.
Create Quick View
Create Design View
Create Projection View
Create Hull View
Create Section View
Create Detail View
Create Basic View
You can also refer to:
Create Regions
