An X plane view is a transverse section, typically on a frame. For example, input FR172 to create the view plane using Frame 172.
A Y plane view is a longitudinal elevation. For example, input LP0 to create an elevation on the centreline.
A Z plane view is a plan view, For example, input Z=5000 to create a plan view at 5 metres above base.
Press the down arrow key and select Fromview to create a hull view from en existing view. Refer to Create Hull View from Existing View with Specified Corners for further information.
Press the down arrow key and select Centre to create a hull with a specified centre point. Refer to Create Hull View with Specified Centre Point for further information.
Press the down arrow key and select Fromview to create a hull view from an existing view. Refer to Create Hull View from Existing View with Specified Corners for further information.
Press the down arrow key and select Corner to create a hull view with specified corners. Refer to Create Hull View with Specified Corners for further information.
Press the down arrow key and select Centre to create a hull from an existing view with a specified centre point. Refer to Create Hull View from Existing View with Specified Centre Point for further information.
Press the down arrow key and select Corner to create a hull view from an existing view with specified corners. Refer to Create Hull View from Existing View with Specified Corners for further information.
