DRAW User Guide
Create and Modify Views : Create Views : Create Projection View
You are then prompted to Specify projection or <Share Drawlist>
Input values in the dimension fields and press Enter or move the cursor the required distance away from the original view, click to confirm the location of the new view. The projection view is created at that point.
You are then prompted to Specify projection or <Finish>
Input F at the prompt and press Enter to end the command. The projection view is created.
Throughout the view creation process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Share Drawlist to reference the drawlist from the source view drawlist.
Press the down arrow key and select New Drawlist to create a new drawlist as a copy of the source view drawlist.
The rest of the procedure is as described in Create Orthographic Projection View, the difference being that a shaded area displays instead of a preview image.
