DRAW
User Interface
Tabs
: Auto
Auto
Create Group
General
Click to display a drop-down list with the following options:
Drawing
Allows you to create a general ADP drawing. Refer to
Create General ADP Drawings
for further information.
Sheet
Allows you to create a general ADP sheet. Refer to
Create General ADP Sheets
View
Allows you to create a general ADP view. Refer to
Create General ADP Views
Spool Drawings
Allows you to create a new pipe spool drawing. Refer to
Spool Drawings
HVAC Sketches
Allows you to create a new HVAC sketch. Refer to
Create HVAC Sketches
Isometric Drawings
Isometric ADP defaults are defined by the administrator.
Refer to
Defaults
Modify Group
General
Drawing
Allows you to modify a general ADP drawing. Refer to
Modify General ADP Drawings
for further details.
Sheet
Allows you to modify a general ADP sheet. Refer to
Modify General ADP Sheets
View
Allows you to modify a general ADP view. Refer to
Modify General ADP View
Tools Group
Equipment Centres
Allows you to define the setup of equipment centrelines on a general ADP view. Refer to
Equipment Centrelines
Isometric Tools Group
Drawing Search
Allows you to search for Isometric ADP drawings. Refer to
Search for Isometric ADP Drawings
Isometric Direction
Allows you to modify the view direction of an Isometric ADP drawing. Refer to
Isometric Direction
Nudge Up
Allows you to increase the view scale of the Isometric ADP drawing. Refer to
Nudge the View Scale
Nudge Down
Allows you to decrease the view scale of the Isometric ADP drawing. Refer to
Nudge Factor
Allows you to define the scale used to nudge the view scale. Refer to
Dimension Cycle
Allows you to define the display style of dimensions on the Isometric ADP drawing. Refer to
Dimension Style
Log
Allows you to view the log file for the generated Isometric ADP drawing. Refer to
Log File
Revision
Allows you to define the revision status of the Isometric ADP drawing. Refer to
Revision Details
Visibility
Allows you to specify the visible layers for the Isometric ADP drawing. Refer to
Layer Visibility
Defaults Group
General
The default files used for General ADP production are defined by the administrator.
Refer to
Set ADP Defaults
Isometric
The default files used for Isometric ADP production are defined by the administrator.
Refer to
Defaults
Pipe Spool Administration
Allows you to define the sheet template and backing sheet settings for pipe spool drawings.
