DRAW
User Interface
Tabs
: Tools
Tools
Display Group
Commands
Click to display the
Command
Window.
Refer to
Command Window
for further information.
Messages
Messages
window, which displays a list of messages issued by the application during the session. Refer to
Messages
Appware Load Errors
Default Load Errors
window. Refer to
Appware Load Errors
Explorers Group
Draw Explorer
Allows
you
to open and close the Draw Explorer. Refer to
Draw Explorer
Department
Click to display a drop-down list with the following options:
Create
Allows you to create a new department. Refer to
Create and Modify Departments
Modify
Allows you to modify the attributes of a department. Refer to
Modify Department Attributes
Registry
Create
Allows you to create a new registry. Refer to
Modify
Allows you to modify the attributes of a registry. Refer to
Modify Registry Attributes
Drawing
Create Explicitly
Allows you to create a new drawing. Refer to
Modify
Allows you to modify the attributes of a drawing Refer to
Modify Drawing Attributes
Model Explorer
Allows
you
to open and close the Model Explorer. Refer to
Model Explorer
Fabrication Explorer
Allows
you
Search Group
Search
Allows
you
to open and close the Search and Search Result windows. Refer to
Search
Collections
Import Group
Excel
Allows
you
to
add Excel tables to a drawing. Refer to
Add Excel Tables
CAD
Allows you to import a CAD drawing as a new drawing sheet or symbol template. Refer to
Create Sheet or Symbol Template from Imported CAD File
Report Group
Run Report
Allows you to run pre-defined reports supplied with the product or created in Report Designer. Refer to
Reporting
Designer
Allows you to open the Report Designer, in which more complex user-defined reports and report templates can be created. Refer to
Reporting
Simple
Allows you to create a report with basic formatting. Refer to
Simple Reports
Clash Plotting
Refer to
Clash Plotting
Defaults Group
User Defaults
Allows you to set user-specific default settings. Refer to
Modify User Defaults
3D Graphics
Allows you to change the 3D graphic settings.
Refer to
Graphics
Current 3D View
Allows you to change view settings for the current 3D view. Refer to
Current View
for more information.
Pick through translucent
Allows you to pick an element through a translucent element. Refer to
Translucent Pick
Context Group
Configure
Allows you to configure the default settings for Design In Context. Refer to
Configure
Browse
Allows you to do all the navigating activity for Design In Context. Refer to
Associated Documents
AVEAVA NET Dashboard
Allows you to display the currently selected item in the explorer in the AVEVA NET Dashboard. Refer to
AVEVA NET Dashboard
