DRAW
User Interface
Tabs
: Annotate
Annotate
Insert Group
Text
Allows you to add text to a drawing. Refer to
Add Text to Drawings
for further information
Symbol
Allows you to insert symbols. Refer to
Add Symbols to Drawings
for further information.
Allows you to insert images. Refer to
Add Images to Drawings
Table
Allows you to add tables to a drawing. Refer to
Add Tables to Drawings
Overlay
Allows you to add an overlay to a sheet. Refer to
Add Overlays to Drawings
Marker
Allows you to place marker points on a drawing. Refer to
Add Marker Points
Annotate Group
Label
Allows you to label design objects. Refer to
Label Objects
Auto-Tag
Allows you to apply automatic tagging to design objects. Refer to
Automatic Tagging
Pipe End Labels
Allows you to add labels to pipe ends. Refer to
Pipe End Labels
Click to display a drop-down list with the following options:
Identified
Automatic
Label Placement
Label Placement
Allows you to tidy up crowded areas of labelling, minimising label overlap and leader-line crossing. Refer to
Label Placement
Label Alignment
Allows you to horizontally or vertically align labels and text annotations,. Refer to
Label Alignment
Gap
Allows you to add gaps to label leader lines. Refer to
Leader Line Gaps
Across PCD
Allows you to add various types of pitch circle dimension annotations. Refer to
Add Pitch Circle Dimensions
Across PCD
Across PCD Leaderline
PCD Leaderline
PCD Pointer Leaderline
PCD Internal Leaderline
Internal PCR
Internal PCR Leaderline
External PCR Leaderline
External PCR Pointer Leaderline
PCR Internal Leaderline
Across Diameter
Allows you to add various types of radial dimension annotations. Refer to
Add Radial Dimensions
Across Diameter
Across Diameter Leaderline
Diameter Leaderline
Diameter Pointer Leaderline
Diameter Internal Leaderline
Internal Radius
Internal Radius Leaderline
External Radius Leaderline
External Point Leaderline
Radius Internal Leaderline
Chained
Allows you to add various types of angular dimension annotations. Refer to
Add Angular Dimensions
Chained
Baseline
Combined
Orthogonal Chained
Allows you to add various types of linear dimension annotations. Refer to
Add Linear Dimensions
Orthogonal Chained
Aligned Chained
Combined Left
Combined Right
Aligned Combined
Baseline Left
Baseline Right
Aligned Baseline
Grid Ruler
Allows you to add rulers to design views. Refer to
Grid Ruler
Active Visual Styles Group
Dimension
Allows you to set the default visual style for dimensions, labels, text and view frames. Refer to
Set Default Visual Styles
Label
Text
View
Ruler
Tools Group
Clean Up Annotation
Allows you to delete elements with null or illegal design element reference (DDNM) attributes. Refer to
Clean Up Annotations
Blanking Margin
Allows you to set the blanking margin for all labels and dimensions on a sheet. Refer to
Label and Dimension Blanking
Enable Blanking
Allows you to turn blanking on for all labels and dimensions on a sheet. Refer to
Disable Blanking
Allows you to turn blanking off for all labels and dimensions on a sheet. Refer to
Model Ref. Check
Turns the Model Reference Check feature on or off. Refer to
Primitives
Select the toggle option to apply the Model Reference Check to primitives when the Model Reference Check feature is active.
Labels
Select the toggle option to apply the Model Reference Check to labels when the Model Reference Check feature is active.
Dimensions
Select the toggle option to apply the Model Reference Check to dimensions when the Model Reference Check feature is active.
