Allows you to define the process tasks used. Refer to Process Tasks for further information.
Allows you to define the process type. Refer to Process Type for further information.
Select the ON option button to apply auto numbering to the process.
Select the OFF to omit auto numbering from the process.
Input a value in the Format field to define a format for the Plot Drawings.
Input a name in the Filename field to define the name of the Plot Drawings.
Input On in the field to display cut marks.
Input Off in the field to hide cut marks.
Input On in the field to display a border.
Input Off in the field to hide the border.
Input On in the field to display a frame.
Input Off in the field to hide the frame.
Input On in the field to allow the file to be overwritten.
Input Off in the field to prevent the file from being overwritten.
Input True in the to add to an existing file.
Input False in the field to create a new file.
