DRAW
Area Based Automatic Drawing Production
Area Based Automatic Drawing Production (ABA) functionality is available with DRAW.
ABA drawings can be compiled by selecting predefined areas and templates created by the administrator. An area is a physical box volume within the database defined by coordinates, and a template is a drawing layout with set parameters that describes a number of views, graphical representation in the views, and types of labelling.
You can produce ABA drawings from the 3D model. A pre-requisite to using ABA is that the administrator has configured ABA functionality.
ABA allows you to produce drawings by selecting predefined physical box volumes (known as areas), these are then matched to a template that describes the format of the drawing to be produced. A typical example of the ABA work process is to update a drawing after a change has been made to the 3D model for a maintenance project.
Functionality is available for you to create drawings using the administrative elements defined by an administrator. If any of the functionality covered does not exist, consult the administrator.
