               Allows you to populate the Existing Drawings list from a list of existing drawings. Refer to Select Existing Drawing drawings for further information.
               Select CE from the drop-down list and click Add to add the currently selected drawing on the Draw Explorer to the Existing Drawings list.
              Select Current List from the drop-down list and click Add to add drawings from the currently selected list of drawings. Refer to Lists/Collections for further information.
               Allows you to rename the currently selected drawing in the Existing Drawings list. Select from the drop-down menu to display the Rename Drawing window.
              You can modify the value in the Name field to rename the drawing.
              Click OK to apply the new drawing name or Cancel to discard any changes and close the Rename Drawing window.
                 Variants can only be selected from the existing drawing list on the Process Drawings Control window.
