Select from the drop-down menu to include the selected combination of templates and areas in the Process Drawings Control window.
Select from the drop-down menu to replace any existing templates and areas in the Process Drawings Control window with the current selections.
Allows you to rename the currently selected drawing in the New Drawings list. Select from the drop-down menu to display the Rename Drawing window.
You can modify the value in the Name field to rename the drawing.
Click OK to apply the new drawing name or Cancel to discard any changes and close the Rename Drawing window.
Click to set a naming convention for the new drawings. Refer to Set Drawing Name for further information.
