Select from the drop-down menu to close the Process Drawings Control window.
Select from the drop-down menu to display the ABA Defaults window. Refer to ABA Defaults for further information.
Select from the drop-down menu to display the ABA Browse Sheets window, which allows you to view ABA drawings that have already been created. Refer to ABA Browse Sheets for further information. Close the browser to return to the Process Drawings Control window.
Select from the drop-down menu to close the ABA Browse Sheets window.
Select from the drop-down menu to display the ABA Template View window and access the views available under the sheet template from which the selected drawing is derived. The functionality of the ABA Template View window is explained, refer to Create and Modify ABA Template View for further information.
Select from the drop-down menu to display the ABA Template Sheet window and access the sheet template from which the selected drawing is derived. The functionality of the ABA Template Sheet window is explained, refer to Create and Modify Template Drawings for further information.
Select from the drop-down menu to display the ABA Template Drawing List window and access the drawing template from which the selected drawing is derived. The functionality of the ABA Template Drawing List window is explained, refer to Modify ABA Template Drawing for further information.
