DRAW User Guide
General Automatic Drawing Production : Modify General ADP View : ADP Schedules
Select the Nozzle_1, Nozzle_2, Valve and Pipe_Support check boxes to apply schedules to the elements in the drawing.
You can modify the position of schedules, click Modify to display the Modify Schedule window. Refer to Modify Schedule Position for further information.
Click Update to apply the schedules, Re-Build to build the schedules table, or Cancel to discard any changes and close the ADP Schedules window.
Input dimensional values in the X and Y fields to define the origin position of the schedule.
Alternatively, you can position the schedule using a cursor pick in the view. Click Cursor to display the Point Construction Option Form window. The functionality of the Point Construction Option Form window is explained as part of the process to define a view frame. Refer to Define View Frame with Cursor for further information.
Input dimensional values in the X and Y fields to define the size of the schedule.
Click Reset to revert to the values applied when the Modify Schedule window was opened.
Click Apply to position the schedule or Cancel to discard any changes and close the Modify Schedule window.
