Although the functionality available from the Fabrication Machine Manager window differs depending on which machine selected from the
Machine Type drop-down list. The
Options part of the
Fabrication Machine Manager window is common, throughout.
Use the Options part of the
Fabrication Machine Manager window to select the element in the
Model Explorer as the CE, display the name or description of the fabrication elements, select an existing fabrication world, group and machine type or create new ones.
By default, the Display Name/Description checkbox is selected populating the fabrication world, group and machine type names. To display the descriptions of these elements, select the checkbox.
Use the Create Fabrication Machine World window to create the administrative element required.
Use the Create Fabrication Machine Group window
Use the remaining part of the Fabrication Machine Manager window to create a new machine, along with attributes, view and/or edit those attributes of an existing machine.
The Bending Dimensions grid is populated with the bending machine information for the selected machine:
By default, the Bending Dimensions tab is selected, the
Bending Dimensions grid is populated with the currently selected bending machine dimensions.
Use the information icon to display a graphical representation of the bending machine information displayed in the Bending Machine Information window. This information is also displayed in a column format in the grid, these can also be modified.
The Collision Planes grid is populated with the coordinates for the collision planes for the currently selected bending machine, a visual representation is also displayed. These coordinates can be modified.
The Stretch grid is populated with the information for the currently selected bending machine, these values can be modified.
The Springback grid is populated the information used to control the accuracy of bending. Refer to
Incremental Springback for further information.
Use the Create Bending Machine window
to create a new bending machine or copy an existing Bending Machine
Right-clicking within the grid on the Fabrication Machine Manager window displays a menu of commonly available options, whatever machine is selected.
The Weldable Flanges grid is populated with a list of flange’s suitable for use with the currently select welded machine. These can be modified and right click menu functionality is also available for selection. Refer to
Grid Menu for further information.
The Welding Dimensions grid is populated with the information for the currently selected welding machine. These can be modified and right click menu functionality is also available for selection. Refer to
The Weld Connections grid is populated with a list of the connection codes for the currently selected welding machine. These can be modified and right click menu functionality is also available for selection. Refer to
Use the Create Welding Machine window
to create a new welding machine or copy an existing welding machine.
Right-click within the grid on the Fabrication Machine Manager window displays a menu of commonly available options, whatever machine is selected. Refer to
The Fabrication Machine Manager window is populated with
Extrusion defaults, allows the creation of extrusions successfully.
The Extrusion Dimensions grid is populated with the information for the currently selected extrusion machine. These can be modified and right click menu functionality is also available for selection. Refer to
The Distance Between Extrusions grid is populated with the information for the currently selected welding machine. These can be modified and right click menu functionality is also available for selection. Refer to
Use the Create Extrusion Machine window
to create a new extrusion machine or copy an existing one.
Right-click within the grid on the Fabrication Machine Manager window to display a menu of commonly available options, whatever machine is selected. Refer to
Use the Weld Gap Options part of the
Weld Gap Config window to define the weld handling information.
If required, modify the values in the SHOP,
FIELD and
SITE fields to define the weld specification for each weld type.
Use the Create Welds for Socket Weld Fitting from Spec check box to create welds for the socket welding fittings from the specification.
FIELD and
Click to select the If component is Out of Spec, use the same source check box to use the same source if the component is out of specification.
Use the Welds for Fitting to Fitting Connection part of the
Weld Gap Options tab to specify the weld type for fitting welds.
The Welds for Slip-On Flanges part of the
Weld Gap Options tab, specifies the weld type for slip-on flanges.
Click Apply to modify the weld gap options, click
Dismiss to close the
Weld Gap Table window.
