Refer to Model Reference Manual for further information on defining rules for setting attributes.
Selection: the elements to which the rule applies.
A Logical test which evaluates to TRUE or FALSE. For example, (ATTRIB ADIR EQ D) specifies that the arrive direction is down.
The Action which AVEVA E3D™ carries out. The actions for logical rules are carried out if the Logical test evaluates to False. For example,
(AXES PP 3 IS N) orientates a valve so that the P3 axis is in the north direction. |
Refer to Pre-processing (PRPR) for further information.
Refer to Orientation for further information.
Refer to Clash Exclusion (CLEX) for further information.
Refer to Post-processing for further information.
The rule is only applied if you set the Change direction using option on the Pipe Router Defaults window to Rule.
The Selection text box contains the expression
The Logical text box contains the expression:
To see the expressions in other rules, select the rule in the list on the Routing Rules window and click Current Rule on the Rule Attributes window.
To view the pipe attributes, with the pipe selected as the CE, on the Piping tab, in the Common group, click Attributes list to display the Attributes window.
The Shoe Height is calculated from the bottom of the pipe not the insulation.
The P&ID file is imported by selecting Create > New Pipes From P&ID. The P&ID Import window displays.
INSU value
/pipe_name/reducer_name
/pipe_name/tee_name
/pipe_name/valve_name
/pipe_name/vent_name
/pipe_name/inst_name
/pipe_name/olet_name
value is the new bore of the pipe for a Reducer (or enlarger), and the P3 bore for a Tee. Any change in bore along a branch can be specified by the BORE keyword. For example:
If a component is at a different bore to the rest of the pipe, for example, a reducing valve, its PBORE0 can be set. AVEVA E3D™ Router inserts a reducer automatically when routing the pipe. An example of this syntax is:
Avoid referring to Elbows using “ELBO n of /B1”: Pipe Router re-creates Elbows every time a Branch is re-routed, and the numbering can easily get changed.
Commands display in a combination of uppercase and lowercase letters, where the capital letters indicate the minimum abbreviation.
The convention does not mean that the second part of the command must be typed in lowercase letters; commands may be entered in any combination of uppercase and lowercase letters.
Command arguments display in lowercase letters. These are just descriptions of what you are required to enter. For example:
Points marked with a plus sign (+) are option junctions which allow you to input any one of the commands to the right of the junction. For example:
means you can type in ABC or PQR or any command allowed by the syntax given in diagram <dia> or just press Enter to get the default option.
Points marked with an asterisk (*) are loop back junctions. Command options following these may be repeated as required. For example:
means that you can enter any combination of option1 and/or option2 and/or option3, where the options can be commands, other syntax diagrams, or command arguments.
