Use the File menu from the
Pipe Router Defaults window, to save settings or load from settings from elsewhere, see System Administrator if new settings are required:
The Pipe Router Defaults window, contains all the tools to determine the defaults for the pipe router.
The Output messages to file fields,
Directory and
Filename specifies where to save and what to name the error messages file. The option to overwrite or add to the end of existing error file by selecting an option from the drop-down list is also available.
Specify a default rule set from the Default rule set world drop-down list for all the branches created by Pipe Router which is automatically assigned as a low priority rule set. Here you or system administrator can create company and/or project specific rule sets. Refer to
Routing Rules for further information.
Specify the minimum Pipe gap between pipes on racks (and other planes), and also specify in the
Pipe gap rounding field the extent to which the gap size is
rounded, which can help minimise construction errors.
Add the pipes to the Pipe Router window, and then route the pipes, Pipes can be added individually or in groups.
By default, the Pipe Router routes pipes in the order in which they are added to the Pipe Router window. The routing order can have an effect on the route taken by pipes. Refer to
Changing the Order in which Pipes are Routed for further information. Pipe Router routes the selected pipes, adding elbows, gaskets and flanges, as required.
The Pipe Router creates a route using an algorithm which minimises material cost while avoiding clashes with other objects. The algorithm has three modes of operation, described as Level 1, Level 2 and Level 3 modes. Pipe Router first searches for a route using Level 1 mode. If no clash-free Level 1 route is found, a search is made using Level 2 mode, and if no Level 2 route is found Level 3 mode is used.
Specify components in a Branch before routing, for example by importing a P&ID file as described in Import a P&ID File. Modify a routed Branch by adding other components, for example, Valves or Instruments, on the
Piping tab, in the
Modify group, click
Component to display the
Piping Component Editor window and create the components in the normal way.
Components can be locked into a given position, in which case they are not be moved, even if the Branch is re-routed. Refer to
Locked Components for further information about using locked components.
How Pipe Router Routes to Free Tails
Tail direction: The TDIR attribute for a free tail is never set if the last constraint is a plane or a rack. In all other cases, TDIR is taken from the direction of the last component.
The Tee must be symmetric about a plane through P-arrive. The Pipe Router changes the arrive p-point to achieve this
if the bores on the p-points are equal. It then checks the leave-bore and connect-bore. If the bores are equal then Pipe Router assumes that the Tee is T-shaped.
Refer to Automatic Pipe Route Administration for further information about creating your own rules.
In Pipe Router, a pipe rack is composed of a group of routing planes which enables the modelling of the route used on a physical pipe rack. There are two ways in which to create a pipe rack. Create pipe racks on existing steelwork structures or model them as a group of planes.
Once the pipe(s) have been routed, check the status of the branch, by selecting Display > Status Summary, the
Pipe Router Status Summary window shows that two Branches have been routed successfully.
Update and Dismiss at the bottom of the Pipe Router Status Summary window can be used to update the report file or close the Pipe Router Status Summary window.
Pipe Router routes pipes in the order in which they are added to the Pipe Router window. However you may need to change the routing order of particular pipes to make sure that Pipe Router routes the most expensive pipes first. Or if working with pipes that are in close proximity to one another or where pipes cross paths.
Auto - Automatically reorders branches according to routing dependencies, that is, if a pipe is dependent on another pipe, then that pipe is routed first. Select this option, for example, after you reorder by bore.
Manual > Pipes - Manually specify the order in which the Pipe Router routes each pipe, using the Pipe Router - Reorder Pipes window.
Manual > Branches - Manually specify the order in which the Pipe Router routes each branch, using the Pipe Router - Reorder Branches window.
By Attribute - Reorder pipes according to particular attributes in ascending or descending order, using the Reorder by Attribute window.
To reorder pipes according to their specification, select Group by specification check box, the display is reordered in alphabetical order of their specification names, for example, all pipes which use the specification A150, followed by all pipes which use the specification B150, and then the other pipe specifications in the sequence. Use this option in conjunction with the attribute radio buttons.
As Pipe Router routes a pipe, it examines each branch and generates a message about any routing errors that it finds. These messages can help you understand and correct errors. It can view these messages both during and after pipe routing, providing you have set up a file in which to store the messages, as described previously
To view routing messages, select Display > Routing Messages from the
Pipe Router window to display the
Routing Messages window.
The Routing Messages window is empty if Pipe Router routes all pipes without any errors.
Select Control > Close to close the Routing Messages window.
Pipe Router enables you to view details of the components and constraints in a branch
using the
Branch Detail window. Select options to constrain the route taken by a branch.
Select one of the routed Branches from the Pipe Router window and click
Branch Detail to display the
Branch Detail window, which contains details of the selected branch.
Refer to Positioning and Locking Components for more information on the contents of the
Pipe Router sees all piping components as deletable, positionable or locked. If the Branch Detail window displays for a Branch that has been routed by the Pipe
Router, all the components are listed as deletable.
After a Branch has been routed, components can be added manually in the normal way. Select the correct element in the Branch Members list, on the
Piping tab, in the
Create group, click
Piping Component Editor window. These components are described as Positionable. If the Branch is re-routed, these components are not deleted, but they may be moved to fit on the new route.
The order of Positionable components in the Branch Members list is maintained, and so is their order relative to any constraints in the Branch. For example, if a Valve is added before a Locked Tee, the Valve is not be moved past the Tee.
To change the status of a component, select it from the list on the Branch Detail window, and then select one of the options under the
Modify menu on the window.
The choices are: Constraint,
Toggle Head Lock,
Toggle Tail Lock,
Lock Position,
Make Positionable,
Make Deletable,
Toggle Head/Tail Relative,
Head W-P, and
Tail W-P.
Each component in a branch is positioned relative to the head or tail of the branch. If a component is head relative, then Pipe Router
places that component as close as possible to the head of the branch, allowing for other components and any constraints. If a component is
tail relative, then that component is positioned as close as possible to the tail of the branch.
Pipe Router routes a pipe from head to tail and so all components are initially created head relative.
Change the head/tail relative property of any positionable component. Select it in the list on the
Modify > Toggle Head/Tail Relative.
From the Branch Detail window, select
Modify > Tail W-P to display the
Modify Tail W-P window.
From the Modify Tail W-P window, select VALVE 1, click
OK.
From the Pipe Router window, select the
Route:
Selected option.
Pipe Router re-routes the Pipe from the Head Work-point to the Tail Work-point, which is now positioned before VALV 1.
Check the position of the valve, display the Branch Detail window for the branch, then scroll to the bottom of the
Components/Constraints list to display the details.
To lock a component, from the Branch Detail window, select the component to be locked in position, select
Modify > Lock Position.
To unlock a locked component, select Modify > Make Positionable for main piping components, or
Modify > Make Deletable for Pipe Router generated components.
To create a routing point, select the required branch from the Pipe Router window
, select
Branch Detail window. From the
Create > Routing Point to display the
Create Routing Point window.
To enter the coordinates on the Create Routing Point window or use the other options available on the menu, which are similar to the normal AVEVA E3D™ positioning options. Routing points can only be positioned after positionable or locked components.
By specifying a different arrive and leave direction, a bend or elbow has to be inserted at the position of the routing point. If a change of direction is not required, select the Through Direction and specify the direction for the pipe to take at that point. If the direction is unset, Pipe Router selects the best direction to minimise the number of bends or elbows used.
There is an option on the Create Routing Point window which allows you to use an existing DATUM point as a routing point. Two branches should not use the same Datum point as a constraint since they would then clash.
To modify the position of a routing point at any time. From the Pipe Router window, select the branch to modify, click
Select the routing point to modify from the Components/Constraints list. Select
Modify > Constraint to display the
Modify Routing Point window. Select one of the following options, depending on the type of modification:
Settings > Apply Rules > To Branch to display the
Apply Rules to SELECTED window.
First select the rule world which contains the rule sets to apply to the branch from the RULE WORLD list, which contains all the Branches selected on the
Pipe Router window. From the
Rule sets available in current world list, select the rule set. The rule set can be added as high priority or low priority.
Click Add HIGH to add the rule set to the
High Priority Sets list or
Add LOW to add the rule set to the
Low Priority Sets list. Click
Apply. You must then route the branch to apply the rules.
From the Settings > Apply Rules options on the
Pipe Router window applies the rule sets to a site, zone or pipe. In these cases all branches which are below them in the hierarchy also have the rule sets applied, unless they have rule sets specifically applied.
By default, Pipe Router applies all the rules in the specified sets to a branch, providing they are appropriate. However, to remove a rule from a particular component in a branch, or add one from another rule set.
To remove a rule set, first select the branch from the Pipe Router window, then select
Apply Rules window, the rule set to be removed must be selected. Click
Remove HIGH or
Remove LOW as appropriate. Click
Apply.
If required, apply a rule to a component from another rule world or rule set, from the Pipe Router window, select the branches to apply the rule to, click
Branch Detail. From the
Branch Detail window, click
Component Rules to display the
Component Rules window, which can be used to add additional rules from the available rule sets, or from another rule world.
From the Rules applying to current component list, select the component that the rule is applied to.
From the Rules available list, select the rule to be applied to the selected component, then click
Include. The rule is added to the list of rules which apply to the component. Click
Dismiss to close the
Component Rules window.
Toprevent Pipe Router from applying a rule to a particular component in a branch, from the Pipe Router window, select the branch which contains the component. Click
Branch Detail window, select the component to be excluded from the rule. Click
From the list of rules that apply to the current component, select the rule to disable from the component, then click Disable. Pipe Router places an asterisk (*) to the left of the rule description to indicate that the rule is now excluded from being used.
To re-enable a disabled rule, select the rule, then select Enable. The rule now appears in the
Rules applying to current component list, preceded by a plus sign (+) indicating that it has been included.
To create a routing plane make sure the STRU element is selected, from the
Create > Routing Plane to display the
Create Routing Plane window, a routing plane element is created in the design hierarchy.
In the Description box, input the description of the routing plane, this text is not used elsewhere in AVEVA E3D™. (It may be useful for keeping a record of the plane’s purpose for future reference).
Top of pipe - Positions the
top of the pipe on horizontal routing planes, or in front
of vertical routing planes adjusting for any insulation. Top
is the Z direction of the Plane which displays with an arrow.
Centre of pipe - Positions the centre of the pipe along the routing plane.
Bottom of pipe - Positions the side of the pipe below horizontal routing planes, or behind vertical routing planes, adjusting for any insulation.
The Pipe to Pipe Gap and
Packing Method options control how Pipes are packed on the plane., refer to
Pipe Packing for further information. Click
OK.
The Routing Plane Dimensions window displays.
Enter the coordinates on the Routing Plane Dimension window or use the other options available on the menu, which are similar to the normal AVEVA E3D™ positioning options.
In the Length box, input the length of the plane, from the
Dir drop-down list, select the direction that the pipes are to be routed along wrt to the plane.
In the Width box, input the width of the plane, then set the direction wrt to the width of the plane.
Click Apply to create the routing plane or
Dismiss to discard any inputs and close the
Routing Plane Dimension window.
The Routing Planes Dimensions window displays.
A vertical routing plane can be created by setting one of the Dir fields to be U or D (up or down). The
up/front direction of the plane is indicated by a construction arrow in the graphical view which is drawn perpendicular to the plane. To reverse the direction, reverse either of the length or width directions, for instance from E to W.
To route a branch via a routing plane, the routing plane must be added to the constraint list for the branch. From the Pipe Router window, select the branch to add the plane to, click
Branch Detail window, which contains details of the selected branch. Select
Add > Routing Plane > Selection to display the
Add Routing Plane window.
Click to check the Last on Plane check box to specify that positionable components are placed on the plane.
Click OK, the routing plane is added to the
Components/Constraint list for the branch or
Cancel to discard any changes and close the
Route the branches, using the Pipe Router, the branches are routed via the routing plane.
Planes are searched for in a box defined by the head and tail of the branch. The box is extended by the values specified in the Pipe Router Defaults window. Only pipes that travel along routing planes a distance greater than the
Minimum Travel Distance are considered.
From the Pipe Router window, select the branch to add routing planes to, click
Branch Detail. Select
Add > Routing Plane > Automatically. The branches appear in the
Command Input & Output window but not on the
Status bar. The
Components/Constraints list on the
Branch Detail window are updated with the selected routing planes.
The Last on Plane check box on the
Add Routing Plane window (and the
Last on Rack check box on the
Add Pipe Rack window) allows you to specify that positionable and locked components are placed on the plane. When it is switched on, the neighbouring list shows all the positionable and locked components in the Branch: select the one required: all the positionable and locked components after the Plane, up to and including the component given as
Last on Plane, are positioned on the plane.
You can have several positionable components on a plane or rack and have more than one
locked component on a rack providing they are aligned.
Reducers are not permitted as positionable or locked components on a plane.
To create pipe racks with several levels, that is several
travel planes. For each level of a pipe rack, a travel plane must be created to control the direction in which pipes travel along the rack and at least one entry/exit plane to make sure that pipes enter onto and exit from the rack perpendicularly, either from above or below. Each pipe rack must have at least one travel plane and at least one entry/exit plane. The direction of travel is the X direction (length) for travel planes and the Y direction (width) for entry and exit planes.
Pipe Router selects the closest pipe rack to the head in the search volume, whose direction takes the pipe closer to the tail, and providing that when using it, the pipe travels on the rack for longer than the
Minimum Travel Distance as defined on the
By default, Pipe Router avoids pockets by first finding the travel plane. If the Head is above the plane, the Pipe enters from above the plane. If the Head is below the plane, the Pipe enters from below the plane. Exit from the plane is similarly controlled by the position of the Tail relative to the plane.
By default, Pipe Router runs pipes along Routing planes with the wall-to-wall Pipe Gap, with any rounding factor for the positioning, as given on the
Pipe Router Defaults window. Refer to
Pipe Packing for further information about how Pipes are packed on Planes and Racks.
Create > Pipe Rack Planes to display the
Create Pipe Rack window.
In the Name box, input a name for the pipe rack, (the name of the STRU element which owns the pipe rack elements displays under the Name).
Select an element in the steelwork, click Convert to display the
Pipe Rack Definition window and pick an element in the steelwork to create the rack from.
The Anchor Plane is the lowest travel plane in the rack.
The Overhang of Entry/Exit planes can be changed. The default value is set on the
Set any Options to apply to all planes in the Rack. Refer to
Pipe Packing Defaults for further information in
Packing Method.
Click OK on the
Pipe Rack Definition window, the Planes part of the
Create Pipe Rack window is now populated.
Click Dismiss to discard any changes.
Pipe Router has automatically filled in the Rack Direction, and the
Dimensions of the rack. The details of the Planes display in the list of
Planes at the bottom of the window. The
Plane attributes area of the window, the display values are those for the plane selected in the
Planes list. The Plane Attributes can be edited for individual planes by changing the values in the window and then click
Include to create a new plane or
Replace to replace the plane selected in the list.
Select the branches from the Pipe Router window and select
Modify > Branch > Add Pipe Rack > Automatically. The status line states which rack is being added to the constraints lists for the selected branches.
To manually add a pipe rack to the list of constraints for a branch, from the Pipe Router window, select the branch, select
Add Pipe Rack window.
The Add Pipe Rack window contains a list of the pipe racks that are available for selection.
Select the required rack, click OK to add the rack to the
Components/Constraint list for the selected branch or
Cancel to discard any selections and close the
Navigate to the STRU element, from the
Create > Structure for Planes to display the
Name Structure for RPLG window, a STRU element is created in the design hierarchy.
In the Name box, input the name for the structure.
Click OK to name the STRU element and close the
Name Structure for RPLG window or
Cancel to discard any inputs and close the
Name Structure for RPLG window.
Create Pipe Rack window. Define the Pipe Rack, refer to
Create and Use Pipe Racks for further information on how to populate this window. Once the Pipe Rack has been created, click
Create Multiple planes to display the
Pipe Rack Definition window. Define the Pipe Rack, refer to
Create and Use Pipe Racks for further information.
The Pipe Router Defaults window also has a
Pipe gap rounding option, which makes sure that the centres of pipe are positioned at rounded coordinates relative to the edge of the routing plane. Coordinates are always rounded up. If no rounding is required, leave this value as 0.
AVEVA E3D™ Router obtains values from the OD (for the current Pipe) or the geometry (for adjacent Pipes), and assume that these are consistent.
set the options on the Create Routing Plane window when
Create > Routing Plane on the
Pipe Router window menu is selected. You can also change the settings for an existing routing plane on the
RPLA Specification window, displayed when
Modify > Routing Plane > Specification on the
Pipe Router window is selected.
set the options on the Pipe Rack Definition window, when you create a pipe rack. You can also change the settings for an existing Pipe Rack on the
Modify Pipe Rack window, when
Modify > Pipe Rack is selected on the
Pipe Router window.
The flange width is the width of the default flange (for example, the flange which is obtained with a SELECT command) for the branches at their current bore, even if there are other flanges on the pipe rack.
If necessary you can change the spacing using the additional pipe-specific gap on the
Navigate to the site or zone where to load the pipes from the P&ID. From the Pipe Router window,
select Create > New Pipes from P&ID to display the
Import P&ID window.
In the Import File text box, input the directory and file name of the P&ID file to load. Alternatively, click
Browse to display the
File Browser which contains a list of the available files, then select the required file.
If you would like to keep a copy of the log file produced during import, in the Log File box, input a file name. Alternatively, click
Modify Elements, do not ask. - Pipe Router modifies Pipes and Branches which are in both the existing model and the P&ID file. If this option is not selected, you are prompted to decide whether to modify the element or not. Minor elements (Valves, Tees and other minor components.) are made unnamed if they already exist, whether this set to on or off.
Do NOT delete generated macro - During import, a macro is created to generate all the components. Normally this file is deleted after import, but if you select this option it is kept.
Show log file after import - Displays the log file. The log file can be displayed later using the Display > Log file option on the menu at the top of the window.
Unname tees after import - If an element has a name in DESIGN, Design Manager attempts to find the name in PEGS. Tees do not exist in PEGS, and so each Tee found generates an error if this option is not selected.
The Modified Pipes & Branches list shows any existing Pipes and Branches that have been modified when the P&ID was read in. As far as possible, Pipe Router attempts to keep any attributes that have already been set in the model, and any constraints that have been added to Branches. However, if the P&ID file requires components to be re-ordered, elements are deleted and re-created in AVEVA E3D™, resulting in attribute settings and constraint associations to be lost.
Messages generated are also output to the Command Input & Output window, if the window displays currently. The log contains messages relating to the progress of the import operation, and any errors or warnings. In particular, the Branch Head must be positioned, if the HREF is not set.
