AVEVA Global WCF Configuration Guide
Certificate Based Authentication : Configure the WCF HTTP Endpoint : Bind Certificate With Windows Vista, Windows Server 2008 r2 or Windows 7
At the certhash parameter, paste the value copied to the clipboard in the previous steps making sure that spaces are removed from the hexadecimal string.
The certhash parameter specifies the thumbprint of the certificate.
The ipport parameter specifies the IP address and port.
The appid parameter is a random GUID (Globally unique identifier) that can be used to identify the owning application.
