AVEVA Global WCF Configuration Guide
Certificate Based Authentication
: Configure the WCF HTTP Endpoint
Authentication can be configured for base product to Daemon, or Daemon to Daemon communications.
The following steps describe the configuration process to bind an
x.509 SSL Certificate
to a Hypertext Transfer Protocol (HTTP) port for the purpose of authenticating incoming requests.
A certificate must be obtained from a Root Authority such as Verisign or Thawte, refer to the following web pages for more information:
http://www.verisign.co.uk/ssl/
http://www.thawte.com/ssl/
The user must install the certificate on Server machine.
The certificate on the Server machine will be validated against the root
Certification Authority
(CA) as shown below:
