.NET Customisation
.NET Customisation
Database Interface
Units
: DbFormat
DbFormat
This object allows formatting of DbDouble's as a string having properties to set the dimension, decimal points, label etc. For example, formatting a temperature
t1 =
DbDouble
.Create(
"0 celsius"
DbFormat
tempFmt =
DbFormat
.Create();
tempFmt.Dimension =
DbDoubleDimension
.GetDimension(
DbDimension
.TEMP);
tempFmt.Units =
DbDoubleUnits
.GetUnits(
DbUnits
.CELSIUS);
tempFmt.DecimalPoints = 1;
tempFmt.Label =
"degC"
string
tempStr = t1.ToString(tempFmt);
or constructing a DbDouble from a string and given format
DbFormat
f1 =
DbFormat
.Create();
f1.Dimension =
DbDoubleDimension
.GetDimension(
DbDimension
.DIST);
f1.Units =
DbDoubleUnits
.GetUnits(DbUnits.INCH);
DbDouble
d1 =
DbDouble
.Create("1", f1);
A DbFormat object has a property that is a pointer to another DbFormat. This format will be used (delegated to) in toString type operations if the value produce by the current DbFormat is less than one.
Delegation can continue along a chain formatting the quantity to ever smaller units. All these format objects must be consistent dimension and progressively smaller units.
