.NET Customisation
.NET Customisation
Database Interface
Data Model Definition Classes
: DbElementTypeInstance
This class contains instances of
DbElementType
for every element type in the AVEVA module. These instances may be used wherever a
DbElementType
is expected, for example: if a method
MyMethod()
takes an
DbElementType
, then you could write:
for example:
MyMethod(Aveva.Core.Database.DbElementTypeInstance.EQUIPMENT);
It is often convenient to add a using statement for these instances, for example:
using
NOUN=Aveva.Core.Database.DbElementTypeInstance;
MyMethod(NOUN.EQUIPMENT);
