The preliminary support is only added to the existing support if unique special support numbering is set to No, refer to Supports Defaults for further information. If the unique special support numbering is set to Yes, the preliminary support is added to the existing support as a reference support. Refer to Reference Supports for further information.
A preliminary support cannot be converted if it is locked or stored in a read only database. A confirm window displays summarising the problem. Click Yes to continue with the conversion process. A new support is created at the same position as the preliminary support in the current supports zone. The original preliminary support is not deleted.
