A preliminary support cannot be converted if it is locked or stored in a read only database. A confirm window displays summarising the problem. Click Yes to continue with the conversion process. A new support is created at the same position as the preliminary support. The original preliminary support is not deleted.
Dependant on the type of support to be converted from a preliminary support, you may be required to select additional components to complete the conversion process. For example, when converting a preliminary support to a slip unit, you are prompted to Identify Atta. You must select an appropriate component to associate the slip unit with. For example an XAT001 general ancillary.
