Input a value in the X-size or
Y-Size text fields to define the dimensions of the compensation plate.
Select the Display Dimensions check box to display the compensating plate dimensions in the 3D view. Clear the check box to remove the compensating plate dimensions from the 3D view.
Click Default to return the compensating plate to the default settings. Click
Reset to return the compensating plate to the state prior to modifying.
