You are prompted to Identify standalone ancillary to add
The ancillary is added to the support as a reference support and a new tab is created for the ancillary in the Support Editor window.
Click to remove a referenced ancillary from the support. A confirm window displays informing you that the changes cannot be cancelled. Click Yes to continue.
You are prompted to Identify reference support ancillary to remove
A confirm window displays asking you to OK the reference removal. Click Yes to remove the reference from the support. The tab containing the ancillary is removed from the Support Editor window.
Click to remove all referenced ancillaries from the support. A confirm window displays informing you that the changes cannot be cancelled. Click Yes to continue.
A confirm window then displays asking you to OK the reference removal. Click Yes to remove the references from the support. The tabs containing the ancillaries are removed from the Support Editor window.
