Supports
Support Editor
Special Supports
: Modify Stiffener Box Material and Size
Sets the material and size of a stiffener box.
If the special support contains more than one stiffener box you must identify the element using a cursor pick in the 3D view.
You are prompted to
Identify stiffener plate (BOX)
The special support name displays at the top of the
Set Stiffener/Material Size
window.
Select a stiffener box to be modified from the list of available stiffeners.
The list of available stiffeners displays all of the stiffener boxes that can be modified for the currently selected special support. Select a material type from the list of available materials.
Xlen
Input a dimensional value in the field to define the Xlength size of the stiffener box. The default size is 100mm.
Ylen
Input a dimensional value in the field to define the Ylength size of the stiffener box. The default size is 100mm.
Zlen
Input a dimensional value in the field to define the Zlength size of the stiffener box. The default size is 100mm.
Select All Stiffeners
Select the check box to define the size and material for all stiffener boxes in the list of available stiffeners.
Click
Apply
to modify the size and material of the stiffener box. Click
Cancel
to discard any changes and close the
window.
