Supports User Guide
Support Editor : Copy
The Copy part of the Support Editor window allows you to copy an ancillary or copy the framework dimensions from an existing support.
You are prompted to Identify source ancillary to copy or <ESC> to finish :
You are then prompted to Identify tube of pipe to add ancillary or <ESC> to finish :
The new ancillary is created and displays on the Support Editor window as a new tab.
Press ESC to finish copying ancillaries.
You are prompted to Identify support to copy framework attributes from
