You are prompted to Identify the new datum ancillary
A confirm window displays asking you to OK the selection. Click Yes to apply the selected ancillary as the datum ancillary.
The reconnection process is dependent on the current hanger type. Refer to Hanger for further information.
You are prompted to Identify ancillary to associate with a crossbar
Press ESC to associate the crossbar.
You are then prompted to Identify crossbar to support the ancillary
You are prompted to Identify Section End Connected or Connection Joint
Select a specification from the drop-down list to define the joint specification for the support framework. The selection determines the options available from the Sub-Type drop-down list and the list of available joint specifications.
Click L, C or R to loop through the left, centre or right Plines for the available options in the justification drop-down list.
