Select a weld from the list to define the weld to be modified. By default, the Section Weld Data and Section Weld Position parts of the Framework Selection window are populated with the details of the currently selected weld.
Allows you to create a new weld for the currently selected support. Refer to Create New Weld for further information
A confirm window displays asking you to OK the deletion. Click Yes to delete the weld.
Click to display the Select Standard Weld window. The functionality of the Select Standard Weld window is explained as part of the process to create a weld. Refer to Create New Weld for further information.
Alternatively click Pick to define the weld start point using a cursor pick in the 3D view. Refer to Weld Start/End Position for further information.
Alternatively click Pick to define the weld end point using a cursor pick in the 3D view. Refer to Weld Start/End Position for further information.
Select a PKEY from the Plines drop down list. You can then click Identify Pline to select a Pline using a cursor pick in the 3D view.
You are prompted to Identify PLIN
Select an intersection from the Intersecting Section drop down list. You can then click Identify GENSEC to select a GENSEC using a cursor pick in the 3D view.
You are prompted to Identify element
