Supports User Guide
Support Editor : Primary and Additional Functions
The bottom part of the Support Editor window displays the Primary and Additional tabs. The Primary tab allows you to process commands that are commonly used. For example, create connections and copy components. The Additional tab allows you to process commands that are less commonly used. For example, add reference supports and compensation plates.
