You are prompted to Identify ancillary in current support
Click to display a 3D view of the special support and the associated ancillaries. Refer to 3D View for further information.
Input values in the Dimensions fields to explicitly modify the dimensions of the lighting support.
You are prompted to Pick surface of ceiling/wall to connect to
By default, connections are made to the identified supporting elements which results in some Dimensions fields becoming inactive. Refer to Supports Connectivity for further information.
