Click Cycle End Position to move the framework support to a different component end position ppoint. Repeat the command to cycle through the available ppoints.
You are prompted to Identify brace member to be modified
Allows you to nudge the bracing by a set distance. Refer to Nudge Bracing for further information.
Select the L option button to lock the Dim ‘L’ dimension.
Select the H option button to lock the Dim ‘H’ dimension.
Select the A option button to lock the angle.
Click to display the View Multi Discipline Standard window. The functionality of the View Multi Discipline Standard window is explained. Refer to View Multi Discipline Support Standard for further information.
The Angle field is not available when positioning a support from ppoint 3.
The Angle field is not available when positioning a support on a cable tray cross.
The Angle field is not available when positioning a support on a cable tray riser.
The Angle field is not available when positioning a support on a cable tray reducer.
