Supports
Modify Support
Delete Support
: Delete Selected Support
Deletes a support.
You are prompted to
Pick Support or <ESC> to finish :
The prompt does not display if the support(s) to be deleted are already selected.
Click to identify the support(s) to be deleted using a cursor pick in the 3D view.
Press
ESC
to delete the selected support(s).
If the support(s) are associated with reference supports, a confirm window displays asking you if reference supports are to be included in the deletion. Click
Yes
to delete reference supports, click
No
to omit reference supports from the deletion.
A confirm window displays asking you to OK the deletion. Click
Yes
to delete the support(s).
