ISODRAFT
Command Reference Section
: ZEROLENGTHSKEWS
ZEROLENGTHSKEWS
Function:
Allows the user to connect a vertical Branch to a falling line.
When modelling falling lines containing Butt Weld Tees or Olets, the user can position a zero-length variable-angle bend at the offline p-point of each Tee or Olet.
Description:
If falling lines containing Butt Weld Tees or Olets are modelled with zero-length variable-angle bends at the offline p-point of each Tee or Olet, the user can connect a vertical Branch. The ZEROLENGTHSKEWS command suppresses dimensioning skewboxes for Butt Weld Tees or Olets in falling lines if zero-length bends have been included in the model.
Bends at Tees or Olets will only be considered as zero-length if they are less than 0.5mm long. Bends with dimensions greater than this will be detailed as normal components.
Examples:
ZEROlengthskews ON
Output skewboxes at vertical connections to falling lines.
ZEROlengthskews OFF
Suppress skewboxes at vertical connections to falling lines.
Related Commands:
FALLINGLINES
Command Syntax:
ZEROlengthskews
ON*
OFF
