ISODRAFT
Command Reference Section
: TITLEBLOCK
TITLEBLOCK
Function:
Allows the user to add extra text to the title block.
Description:
The title block is produced automatically. Extra text can be added to the title block by using the TITLEBLOCK command, followed by the line number and the text to be added.
Title block lines can be input in any order.
The user can underline a line of text by putting the _ character (underscore) at the end of the line.
The user can create a vertical bar from the previous horizontal line down to the next horizontal line by putting the | character (vertical bar) in the text.
ISODRAFT will accept a maximum of 25 title block lines. Each line may contain up to 39 characters (including spaces, but excluding the underscore character).
Examples:
The following sequence will add the text illustrated below:
TITLE 1 ’THIS IS AN EXAMPLE OF THE EXTRA’
TITLE 2 ’TITLE BLOCK INFORMATION’
TITLE 4 ’A VERTICAL LINE WITH |’
TITLE 3 ’TO UNDERLINE USE THE UNDERSCORE _’
Related Commands:
DATE POSITION
Command Syntax:
>--- TITleblock ---
value
text
Querying:
Q TITleblock
Q TITleblock
value
Q OPTions
