On UNIX workstations, the RECREATE command can be used to create a macro file which can then be read into ISODRAFT again to recreate the existing option settings or the detail list. Refer to Software Customisation Guide for more information about writing and using macros. The user can also use the RECREATE command to save the screen layout, which can then be read in again using the INSTALL SETUP command.
>-- RECReate --+----------------.
| | |-- OPTions -----| | | ā-- DETAillist --+-- filename --+-- OVERwrite --. | | ā---------------+--> |
