ISODRAFT
Command Reference Section
: PBENDNUMBERS
PBENDNUMBERS
Function:
Numbering the pulled bends in Spool Drawings on an isometric.
Description:
By default SPOOL automatically generates numbers for every pulled bend in a Spool Drawing. These numbers can be output on an isometric, by switching PBENDNumbers ON.
This function has no effect when plotting isometrics from the DESIGN database.
The bends are sequentially numbered from one end of the Spool Drawing with a default prefix of ‘B’. The numbers are displayed in a diamond, with an arrow pointing to the pulled bend. If the total number of characters (prefix + number) is greater than 3, the number is displayed in angled brackets; e.g. <B232>.
Examples:
PBENDN ON
Switches pulled bend numbering on.
PBENDN OFF
Switches pulled bend numbering off.
Related Commands:
JOINTNUMBERS WELDNUMBERS
Syntax Graph:
>--- PBENDNumbers ---+--- ON ----.
‘--- OFF ---+--->
Querying:
Q PBENDNumbers
Q OPTIONS
