Creates a material control file.
This filing command always operates in append mode: that is, new data is always added to the end of any existing file of the same name rather than overwriting the current contents. If the specified file does not already exist, a new file of that name is created.
Material Control File defines the codes used to identify the records.
>--- MATControl ---+--- name ---+---EXTended--.
| | | | ‘-------------| |--- OFF ------------------| | | ‘--------------------------+-- OVERwrite --. |
