ISODRAFT
Command Reference Section
: MARK
MARK
Function:
Defines if the Pipe revision attribute (REV) should be incremented and if the Branch detail attribute (DETA) should be set to TRUE after successful detailing by ISODRAFT.
Description:
By default, the REV and DETA attributes will not be changed when a pipe or branch has been detailed.
If MARK DETAIL ON is set, the DETA attribute for each Branch detailed will be set to TRUE.
If MARK REVISION ON is specified, the REV attribute of each Pipe detailed will incremented.
By default, ISODRAFT will not detail a pipe if any of its branches has its DETA attribute set to TRUE. To override this, use the command MARK IGNORE ON.
The MARK command generates an inter-DB macro, to be run in MODEL to set the REV and DETA attributes as described. This macro will be created (in the project's XXXMAC directory) only when the user carries out a module change or execute a SAVEWORK command.
Examples:
MARK DETail ON
Sets the DETA attribute of each Branch to TRUE.
MARK REVision ON
Increments the REV attribute of the Pipe.
The defaults for the detail and revision flag options are:
MARK DETAIL OFF
MARK REVISION OFF
MARK IGNORE OFF
Command Syntax:
MARK
DETail
REVision
IGNOre
ON
OFF*
Querying:
Q MARK
Q OPTions
