ISODRAFT
Command Reference Section
: MARGIN
MARGIN
Function:
Specifies the width of the margin on each side of the drawing.
Description:
By default, a 5mm wide blank margin is provided on each side of the drawing area. The MARGIN command allows the user to specify the widths of the left, right, top and bottom margins independently.
Examples:
MARGIN TOP 0.5 IN
Sets top margin to 0.5 inch.
MARGIN L15 R15 T25 B25
Sets all four margins in a single command line (assumes current units are mm).
Command Syntax:
MARGin
Left
value
Right
value
Top
value
Bottom
value
Related Commands
RESERVE
Querying:
Q MARGin
Q OPTions
