ISODRAFT
Command Reference Section
: ITEMCODE (2)
ITEMCODE (2)
Function:
Specifies whether or not specification names are to be included in material list itemcodes, and whether items which have the same itemcode except for the specification name and suffix are treated as the same item.
Description:
By default, itemcodes shown in the material list do not include the name of the Specification from which the material data has been extracted. This is known as a short itemcode. The ITEMCODE LENGTH command allows the user to use the full SPCOM, which includes the SPEC name but excludes the suffix, as the itemcode.
By default, ISODRAFT removes any itemcode suffixes before comparing itemcodes for totalling in the material list. The SEPARATE option allows itemcodes to be compared before the specification name and suffix are removed, thus allowing itemcodes to be listed separately with different descriptions.
The user can set up multiple itemcodes for elements in the DESIGN database by creating user-defined attributes (UDAs) for the SPCOM of the element. For bolts, the UDAs are created as attributes of a DTAB element. The user can then use the ITEMCODE command to specify that the itemcode should be taken from a UDA instead of from the SPCOM.
The Item Code for a Support may be derived from a Standard Text Attribute, Text UDA or Property of the ATTA itself rather than from its SPCOM.
Examples:
ITEMCODE LENGTH LONG
Itemcodes to include SPEC name.
ITEMCODE LENGTH SHORT
Itemcodes to exclude SPEC name.
ITEMCODE TOTAL
Itemcodes which are the same except for the specification name and suffix are totalled.
ITEMCODE SEPARATE
Itemcodes which are the same except for the specification name and suffix are listed separately.
ITEMCODE FROM :ABC
Itemcodes to be taken from the UDA named :ABC. The UDA must exist for SPCOMs.
ITEMCODE FROM SPREF
Itemcodes to be taken from the SPCOM.
ITEMCODE FOR SUPPORTS FROM FSTATUS
Itemcodes for Supports to be taken from the FSTATUS attribute of the Support.
ITEMCODE FOR SUPPORTS FROM :MDSItemCode
Itemcodes for Supports to be taken from the :MDSItemCode UDA of the Support.
ITEMCODE FOR SUPPORTS FROM PROP RNAM
Itemcodes for Supports to be taken from the RNAM Property of the Support.
Related Commands
MATERIALLIST DELIMITER
Command Syntax:
>-- ITEMcode --+----------------------.
‘-- FROM --+--SPREF* --+- LENGth --+-- LONG ----.
| | | ‘-- SHORT* --|
| | |-- TOTal* ----. |
| | |-- SEParate --+---------|
| ‘-- :udaname ------------------------+-->
‘--FOR SUPPORTS FROM --+-- SPREF* --------------+
‘-- :udaname ------------+
‘-- attribute -----------+
‘-- PROP property -------+-->
Querying:
Q ITEMCODE
Q ITEMCODE LENGTH
Q OPTions
