Defines whether the isometric will show fabrication information, erection information, or both.
A combined fabrication-erection isometric is a fully dimensioned and annotated isometric drawing with a material list specifying all piping components, bolts etc. This is the default.
A fabrication-only isometric is similar to the combined format except that the following information is omitted:
The erection-only isometric is similar to the combined format except that all fabrication materials, apart from loose flanges, are omitted from the materials list.
A spool isometric only shows fabrication information. Loose flanges will be included on spools, with the note ‘tack weld only’, if they have a SHOP attribute set to TRUE.
Sheets with Blank Drawing Areas. Any type of the isometric can be produced with the actual drawing area left blank, that is, only the material list will be plotted.
>-- ISOType --+-- COMBined* --+-- ERECtion ------.
| | | | |-- FABrication ---| | | | | ‘------------------| | | |-- ERECtion --+-- FABrication ----| | | | | ‘-------------------| | | |-- FABrication -------------------| | | |-- SPOOl -------------------------+-- NOPicture ---. | | | | ‘----------------| | | ‘--- NONe ------------------------------------------+-> |
