ISODRAFT
Command Reference Section
: INSTALL SETUP
INSTALL SETUP
Function:
Produces the screen layout stored in a file created by the RECREATE command.
Description:
On workstations, the user can use the RECREATE command to save the screen layout, which can then be read in again using the INSTALL SETUP command.
Examples:
RECReate /DISP
Saves the screen display in a file named /DISP.
INSTALL SETUP /DISP
Restores the screen display stored in the file /DISP.
Related Commands
RECREATE
Command Syntax
>--- INSTALL SETUP filename --->
