ISODRAFT
Command Reference Section
: FRAME
FRAME
Function:
Specifies whether or not drawing frame lines and text are to be drawn.
Description:
By default, ISODRAFT plots a frame around the complete drawing within the predefined margins, together with separating lines between the different areas. Frame text and line summary symbols are also plotted.
The FRAME command allows the user to switch these features off or on.
Related Commands:
CUTMARKS MARGIN
Command Syntax
>--- FRAMe ---+--- ON* ---.
‘--- OFF ---+--->
Querying:
Q FRAMe
Q OPTions
