ISODRAFT
Command Reference Section
: FIELDSOCKETWELD
FIELDSOCKETWELD
Function:
Allows you to specify which symbol is used to represent a Field Socket Weld.
Description:
This command allows you to specify which symbol is to be used to represent a Field Socket Weld.
Examples:
FIELDSOCKETWELD OBLONG which specifies:
FIELDSOCKETWELD CROSS which specifies:
Command Syntax:
>--- FIELDSOCKetweld ---+--- OBLONG --------------.
‘----CROSS------------+--->
The corresponding GUI os displayed on the
Annotations Options
window.
